SicAudio
did you fart dude?
12db or 24 makes no difference to the issue at hand here dude
if you are hearing voice something is ****ed in the amp or you are adjusting it wrong
that is your amp correct?
Install tips:
There is definitely inadvisable the installation of his amplifier SounDigital in
vibration places like the speaker box and also in places where there is no
refrigeration. Prefer open places, fixing the amplifier with four screws.
Input Sensitivity adjust:
To adjust the input sensibility of the SD8000.1D it is necessary to do this
procedure: With the speakers connected to the output terminals of the
amplifier, adjust the volume of the radio around 70 % of the maximum and
adjust the input level of the amplifier until the clipping led begins to blink in
synchronism with the music peaks. In this point the maximum power is
obtained without danger of damaging the speakers.
Guarantee:
Your SounDigital amplifier has 1 (one) year of guarantee against
defects of manufacture counted from the purchase of the product. Bad use will
have the repair charged.
Contact:
Mail: soundigital@soundigital.com.br
Installation Manual
SD8000.1D
Presentation:
Congratulations on your purchase of the world's newest brand of car audio
amplifiers.
You acquired a very good quality amplifier! This
amplifier uses the highest technology in class D amplification
and is made of components of the best quality. The project of
the system took several years to reach a very high level of
quality and reliability, with exhaustive tests of quality and
power for the total satisfaction of the client.
Especifications:
-8000WRMS @ 12,6V
-6400WRMS with twice the nominal impedance
-Maximum consumption = 1000A
-FA (damping factor) = 200 @ 1 ohm
-Operating frequency = 20 Hz a 8 KHz
-Subsonic variable filter = 20 to 50Hz
-input sensibility = 0,5V -6V
-THD
-All the protections have different indications.
-All the protections are resettable
-Protection for sub-tension of the battery at 8 volts (blue LED blinks 10 times)
-Protection for over-tension of the battery in 16 volts (blue LED blinks 10 times)
-Output short-circuit (yellow LED blinks 10 times)
-Protection for sub-tension of the batteries (red LED blinks 10 times)
-Protection for temperature (red LED remains lighted until the temperature
decreases)
-Totally microcontrolled amplifier
-Clipping indicating LED
-Discharged battery indicating LED
-ESM – Energy Saving Mode
-High-current connectors
-Nickel-plated connectors
-Soft-Start and Soft-Stop
-Ultra-Low noise SMPS
-Internal Cooler with actuation only above 104F.
-Dimension: 17.32” length x 10.9” width x 2.87” height.
-Weight: 24.25 lbs
Installation:
The installation is very important! A bad installation can damage the
product or the car, and may affect the guarantee.
It is recommended the use of 2/0 AWG electric cables. For the speakers
is recommended at least 8 AWG. The grounding is very important, since it is
going to inhibit the appearance of noise and allows full power. The battery
capacity must be in order of 600Ah. The use of fuse is recommended at the
batteries positive terminals.
The remote cable must be connected to electric antenna of his radio. It is
recommended the use of a fast-action 500mA fuse near to the radio.
Never touch the outputs of the amplifier, danger of electric shock.
Crossover:
The crossover of the SD8000.1D has 2 different controls, the subsonic
filter and the LP filter. The subsonic filter is adjustable (20 Hz up to 50 Hz) and it
removes the frequencies below the set value. The LP filter (adjustable between 80
Hz and 8 Khz) removes all the frequencies above the set value .SLOPE: 12 dB/8ª.
Features:
Energy Saving Mode: Every time the SD8000.1D detects that the audio
signal had the volume attenuated the amplifier starts the E.S.M. In this mode it
will work normally consuming half of the normal energy. The blue led will reduce
the intensity to show that E.S.M. in on. When more energy is demanded the
SD8000.1D will return to the normal mode automatically. The red LED monitors
on-line voltage of the battery, every time the voltage reaches 10,5V the LED
lights.
Install tips:
Guarantee:
Contact:
Installation Manual
SD8000.1D
Presentation:
amplifiers.
Especifications:
-8000WRMS @ 12,6V
-THD
decreases)
-Weight: 24.25 lbs
Installation:
Crossover:
Features:
lights.
