Sound Stream XXX6500
whats the max draw from that amp? sounds like its way over 200amps. you will probably need 2-200 amp alts
edit: website recommends 16 volts. are you going to run your system at 16 volts?
I guess so - if full volume test tones are the daily listening material.
I think that's just for the SPL comps when that extra couple tenths of a dB matter. At 14v it should easily do 4kw.
WhiteIce
WhiteIce
Lima,Ohio
jrobb
