Sound Leakage in Vintage Car?
I've done a lot of installs in older cars and haven't had too much problems with "leaking bass" but I noticed its a lot harder to get bass into the cabin depending on where the enclosure is mounted in those massive trunks
Alright, I think im going to get some dynamat. Im seeing prices on eBay for alot cheaper than on the dynamat website. I do have a question:
Alright, so if you put dynamat in your car, it will cut out the sound/bass from excaping? Well dont you want all of your bass to be exposed so people outside your car can hear it?
Also - does the trunk kit come with the roller, or do I not even need one?
is this a serious question?
if it is serious, then it all depends on why you have a system.
if you have one, so you can enjoy your music on a different level than a stock system can produce, then no, you want as little sound to escape as possible.
if you have a system, so you can drive around like an idiot with your bass cranked all the way up showing off how much of a tool you are to everybody that DOESN'T care, then yes, you want your bass to be exposed to all the innocent bystanders around you.
Bobby322
Bobby322
TX
yne721
ThxOne
    May 25, 2026
