Sound deadening trunk lid question
ryanthie
Needs moar loud
I know you should deaden as much as you can, but I have a little question about my car.
'03 Protege. It has spots in the trunk lid that are gapped for license plate lights and bolts.
Question is, should I deaden the metal inside the gap where I can reach, or will deadening over the holes be sufficient enough?
You really only need to deaden the large flat surfaces. Round surfaces generally have enough strength as to not resonate anyways. 25-40 percent coverage is more than sufficient for the majority of systems.
what are your actual goals for this?
Getting rid of metal on metal rattle
Most of my lid has flat surfaces and the only rounded areas aren't too large really. Though knowing that will save me deadener to put in my doors though.. bottom of my trunk has quite a few rounded areas.
ryanthie
Needs moar loud
ryanthie
Spokane, WA
calebkhill
