Sound Deadening Install w/ Pics
Tips
I started my sound deadener install today. I used edead v1se2 It took me four hours to do one door. But the midbass response I got after the install was amazing. Everthing sounds cleaner. Feel free to leave comments.... I think I should have used more than one layer, but nonetheless, it was worth the time. I can't wait to do the other door and then my trunk.
Did you end up sealing over the big holes? Pictures didn't really tell for sure...Also, how much of the outside sheet metal were you able to deaden? Looks like it would be hard to get it all the way it is on that car.
Yea, I'm from Plano, TX. And No I didn't end up sealing over the holes. I wasn't too sure if it would make that big of a difference. You guys think it would? I was able to reach most of the outside sheet metal if not all. There was a small hole above the speaker, you can see it in the picture. So I used that to reach the right side of the door. I wasn't able to roll it on with the hair dryer as well, but I tried, and there's two layers behind the speaker. Should I cover the big holes?
Tips
Tips
Plano
PsychoTheRapist
