Sound deadening in box?
oh fudge sticks.
If you want to gain volume, I've used polyfill to do that in smaller spaces, so if the box is too small for the sub, you could gain some sound, but if your box is already built to spec, I would just go back around the edges with silicone caulk and "freshen" it up a bit, otherwise with the trunk deadened you should hear it better as well.
OP the most you can do to the inside of your box is add in like fiber glass to help strengthen it. Deadener is just for getting rid of rattles not to make something more rigid, per-say.
Sound proofing the interior of an enclosure is like using an airconditioner for just the "fan only" setting. It will not hurt the enclosure, but it will affect the output. Though you do not want many resonances inside an enclosure, its inevitable. The best way to increase the sound intensity is by minimizing folds in the design, but sound deadener is not the answer.
All these answer are most likely just guesses. i speak from experiance when i say the only thing you will gain is a few tenths on the meter, and thats ONLY if its done perfect and super smooth. some of the usaci world champions have done it and max gain i have seen is .5 dbs. So if your chasing numbers then do it. otherwise its just a PITA
Somewhat agreed. Panel resonances tend to smooth out a resonse curve, so if you are looking for less panel resonance, then yes, by eliminating it you will gain numbers, but bracing is more efficient for that purpose. With a large enough enclosure, both could be utilized, but if the sole purpose is for audible experience, which music is intended for, then it would do nothing but cost time and money. For that small of a gain when the purpose may be for that extra "loudness" then its not worth looking into it. For dB comps, when audible experience is null, then by all means. But weigh the options and cons/pros first. Having a **** box and wanting to put this in it will not be worth it. Having a specifically design enclosure matching all aspects of the competition as well as possible, maybe.
I would also be willing to almost bet that doing a nice smooth well done layer of resin on the inside of that box will do far more than deadening. Like Moble said though, nothing is a replacement for good bracing. Dont try to hide a problem if you can solve it. If you are trying to just "improve your sound" you most likely wouldnt notice anything.
kramer_212
kramer_212
Minnesota
SPLaudio
