agreedI doubt if it's enough. It might be, but cutting it pretty close. I'd suggest you do the doors and the trunk first since that's where your mids and subs will be, respectively. Then if you have leftovers, do the floors //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
but, but, but...that only measures things one dimensionallyApproximating square footage is very easy using one of these.![]()
Latter means last in a series //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gifWell depends I guess. Some people think that just putting the deadener in spots will stop the rattles, other people say you should cover 100%. Me I am covering 100% due to me doing the latter and it didn't work out so well. So no it won't be enough if you want to 100% cover those area's. I used over 60sqft just in my trunk covering 100% of it.
Yes sir, you are correct! Thanks and I knew that, but................my chair smells like ****! I hate when I relieve that stupid Loss Prevention guy before me. I am gonna have to break out the lysol and spray this bish down!Latter means last in a series //content.invisioncic.com/y282845/emoticons/fyi.gif.9f1f679348da7204ce960cfc74bca8e0.gif
Word!200 sqft and counting. This includes complete crap to very good. You name it, it's in my car. This does NOT include the "deadener" that was removed due to failure. Mistakes add up in time and $$$$.
Doors ~5 sqft x 3 parts x 2 doors (unless you have speakers in the rear). Easy.
The roof is can be easily estimated. 15-20 sqft, single layer.
Why is it called "sound deadener" when the goal, though it's proper application, is to make our sounds sound alive? //content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
how exactly do you apply it correctly?Fatmat is asphalt based. This is generally considered bad because it doesn't adhere well. You want a deadener that's butyl based, like Damplifier, or Raammat BXT. That said some people will tell you if you're willing to put forth the effort to apply the fatmat correctly it shouldn't have any problems.
