Sound Deadener: Audio Technix or Second Skin Damplifier
So it just saves you money. Im still gonna sound deaden my whole rear deck doors and parts of the trunk by the exhaust.
I guess if your reading comprehension is off. The purpose is because anything more wont net you better results, but at the same time your tossing money out the window. It will actually hurt results. Im sure you will also apply deadener to rigid surfaces even though they are more resistant to vibrations than a flat panel.
Controlling resonance is the absolutely critical first step in any sound deadening project, but more isn’t better and trying to use a CLD to block sound is too expensive, too labor intensive and makes it unnecessarily difficult to do future vehicle maintenance.
To control panel resonance you should use the best vibration damper you can find and only treat the 25% at the center of the panel.
So what you are saying i should not sound deadon my doors completely or my rear deck? Or just a portion of my trunk?
You should deaden 25% of it. If you dont want pieces to rattle against each other or you want to keep out air borne/road noise then you need a closed cell foam or an mass loaded vinyl.
I don't see how applying more then 25% would hurt results.
It will only hurt performance if you are going for SPL - vibration dampers convert vibration, which can become sound, into heat, which can't. Other than that, diminishing returns come in very quickly after 25-30%. If you're using more than that, you're probably trying to use the vibration damper for something else: either as a stiffener, something it's not very good at, or a barrier, something else it's not very good at. You're also adding future maintenance problems for no real return in performance. There's just no good reason to do it.
well truth is it only saves you money and you don't need more then 25% for sound improvement, however if you're using it to chase down and secure rattles thats a different story, cover that bish in it.
It can only hurt performance if you are going for SPL - vibration dampers convert vibration, which can become sound, into heat, which can't. Other than that, diminishing returns come in very quickly after 25-30%. If you're using more than that, you're probably trying to use the vibration damper for something else: either as a stiffener, something it's not very good at, or a barrier, something else it's not very good at. You're also adding future maintenance problems for no real return in performance. There's just no good reason to do it.
Fixed
ANT
Drummer65
Drummer65
Newport Beach, CA
Anthony Collova
