Sony XS-L100P5W Specs/Parameters
bigone5500
Hi, Great forum. I was wondering if anyone here has any info regarding the Sony xs-l100p5w 10" subwoofer. I am using win isd pro and need some parameters for this speaker. I'm wanting to design a ported enclosure for it. Thanks!
it means that ppl will bash you because you dont own what they do, as for tuning the box without the the subs parameters, people do it quite often. but good look finding the parameters may wanna try google though.
Just hit any driver, the whole T/S parameter thing is overrated anyway. Besides, with that woofer, SQ isn't a priority. Pick any 10 from the list and put in the volume and tuning you want. Then you have your port length.
Thanks guys. I called sony's tech support and found out that they use scoche for it. They emailed me the TS Params for it. Thanks...
870
I just got a sony cdx-f7715x put in my truck. It’s in demo mode right now cause I don’t have a remote to access the menu. Is there any way I can...
Are your tweeters amplified or powered by the radio or maybe factory amp? I'd check your wiring for sure, make sure 12v power and ground are...
That looks like it can work for backup cam for sure, thanks
978
Did the articles on issues with this unit not getting audio directly after installing, have any fixes. Is it possible that you are experiencing...
bigone5500
bigone5500
Louisiana
bigone5500
maylar
    Jun 2, 2024
    Jun 1, 2024
