Sony 1000watt Mono Amp Question
XplodX
I have a sony Xplod Mobile ES Xm-6001GDX amp and 2 12" Mobile ES XM-1225G 1200watt subs. I want to hook both the subs up to this amp and dont really understand the mono block thing. Could somone please explain to me how I would do this and what kind of wattage I would get to each sub. Thanks
-XplodX
i could'nt find that sub online... but the amp is rated as follows:
300w X 1 @ 4ohm
600w X 1 @ 2ohm
1000w X 1 @ 1ohm
tell me the specs of your subs and i will tell you how to wire them.
I think your sub model is the XS-L1255G which is a single 4 ohm voice coil
subwoofer.
Since you have two of them, you "MUST" wire them in parallel to get the
most from your amp. In parallel mode you will get a 2 ohm load.
Each sub will get about 300 WATT RMS, that will be just fine cause
your subs are rated at 400 WATT RMS -- 1200 W MAX.
Hope this could be helpful.
to wire parallel, run the pos of one vc to the other vc on each sub. do the same with the neg of each vc. then connect one pos of each sub together and run that to the amp. do the same with the neg of each sub. you're now in parallel and running 1ohm. that should put you close to 500 wrms to each sub.
690
I just got a sony cdx-f7715x put in my truck. It’s in demo mode right now cause I don’t have a remote to access the menu. Is there any way I can...
Are your tweeters amplified or powered by the radio or maybe factory amp? I'd check your wiring for sure, make sure 12v power and ground are...
That looks like it can work for backup cam for sure, thanks
917
Did the articles on issues with this unit not getting audio directly after installing, have any fixes. Is it possible that you are experiencing...
XplodX
XplodX
Mendocino,CA
natem33
    May 12, 2024
Brendon Jenness
    May 11, 2024
