Kenwood amp problem
eljohnny1
I have a Kenwood 739S amp which is rated at 600 watts max it is running two audiobahn 12s 800 rms it stopped working today for no reason do you guys think it is an electrical problem or did the amp fry or what , it was not working fine since I got it a couple of days ago it had like a short stop between beats and this was only the subs not the normal speakers this was usually at not so high volumes about 14 on a Alpine head unit with sub control
i put a pic of the subs
forot about the pic my bad
well i would check all the fuses, on the battery and remote wire on the back of the head unit and then check the ground, i have had probs before with the grounds on kenwood amps if none of that seams to help take it too a local place that can test it.
Originally posted by eljohnny1 I have a Kenwood 739S amp which is rated at 600 watts max it is running two audiobahn 12s 800 rms it stopped working today for no reason do you guys think it is an electrical problem or did the amp fry or what , it was not working fine since I got it a couple of days ago it had like a short stop between beats and this was only the subs not the normal speakers this was usually at not so high volumes about 14 on a Alpine head unit with sub control
THE CAR AUDIO IS O.K THE KENWOOD AMP HAS TO GO WHY BY **** KENWOOD KID **** FOR 16 YEARS OLD IAM WITH TEAM ROCKFORD AT THE POWER LEVEL ALL I CAN SAY IS SAVE TOUR MONEY AND BUY THE GOOD **** KICKER ROCKFORD CERWIN AND MORE?????
Originally posted by Unregistered THE CAR AUDIO IS O.K THE KENWOOD AMP HAS TO GO WHY BY **** KENWOOD KID **** FOR 16 YEARS OLD IAM WITH TEAM ROCKFORD AT THE POWER LEVEL ALL I CAN SAY IS SAVE TOUR MONEY AND BUY THE GOOD **** KICKER ROCKFORD CERWIN AND MORE?????
Don't you have to be literate to be a part of Team Rockford?
hey i have some good advice for you team rockford guy, read over your post before you submit it, i found 18 errors in your post, good job dumbass
I would keep the amp you have and keep the components. Place the components in some universal door pods, and look at getting a powered SAS 8"...
13
Honestly I don't think it would be hard for them to make it where you use android auto AND your own music source. They made it able to do so...
5
190
@Deiimos Hit it on the spot from the beginning of a bad ground. Excellent! Im happy to hear that you went through some procedures to locate the...
20
564
I got it to work, I was plugging in the subwoofer while the amp had power. I unhooked the remote turn on lead, then all speakers plugged in, then...
4
536
eljohnny1
eljohnny1
Dallas, TX
Doxquzme
    Apr 28, 2024
Doxquzme
    Apr 28, 2024
Latest topics
