something wrong maybe
hmmm dont think thats too safe. i have tested that and i got more stink playing under tuning than at/above tuning
its safe, why would you not want to play below tuning at all?
id keep the ssf about 10hz below tuning. my box is tuned to 36hz and i keep my ssf about 20hz.
i could help ya maybe this weekend man. make sure your subsonic is at your tuning freq not below for whoever told you that. set you lpf to about 60 and set you gain up at around half. if nothing still then post on here and let me know how that went
2 HDC's off a single 2200 won't be pushed hard enough to hurt themselves playing below tuning...
ok ill explain how everything is wired to see if i messed up somewhere.
each sub is wired one coil + to - (on same sub)
other coil is + to + and - to - (between subs and to amp) so wired to 1ohm.
how would i test rca voltage?
also this is the settings:
i have a d4 re se laying around. ill just hook that up real quick to see if it works. if it does i know its not anything but the subs. deck is alpine 9886
Ok so I got my frontstage amp working fine. Aq amp gets power. Stays on and everything. Subs still move but just like vibrate and no output. I connected one f my re se 15s freeair to see if it moved, an it vibrate some but not tons
taintedplay
taintedplay
dallas
taintedplay
