Something about wiring amps
flakko
Veteran (my butt)
i got a lito question about wiring two amps to a HU. I understand how to wire everything except the turn on wire since there is only one turn on wire from the HU, how am i supposed to go about hooking two amps to one turn-on wire??
just twist another wire on somewhere on the remote turn on wire and cap all the ends together.
so your saying add another wire onto the HU from the existing wire right???
is that bad for the hu?? or am i just being paraniod
I daisy-chained my amps together...as long as you're not running more than two or three amps off the head unit, you're fine.
Also, I stuck a 500mA fuse on the remote turn on lead where it came out of the wiring harness - "just in case".
I did exactly the same with my two amps...not a lot of current flowing through the remote wire, so a couple amps wired together should be O.K.
I wouldn't run anymore than 2 amps on a remote wire. 3+ and I would use a relay. To wire the turn-on to another amp, just run a wire from the remote wire on your other amp to this new amp (i.e. daisy-chaining).
ehh here i draw picture... like this?
flakko
Veteran (my butt)
flakko
So Cal
flakko
