Somebody design a box for me for $$$
http://www.subwoofertools.com/forum/ported-box.asp?Ew=38&Eh=18&Dia=6&Xmax=19&Vd=.1&NumW=3&Vb=6&Fb=32&Qts=&Vas=&Fs=&CE=0
have fun trying to fit three 12's on there //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
they'll probably have to be on top, port back. subs not in a line.
Yeah I know. The re calculator is better. I was playing around with it and got a decent design. I'm just looking for something maybe a little unique. I sent an email to team toxic as well to see what they come up with.
If I run the port the width of the box, and on the bottom, I can run all three subs in a staggered line, 1 a tad higher than the other 2.
Here you go. Just designed one right on the numbers.
37 1/4 x 26 x 18 tuned to 30Hz @ 6.3 cu/ft
(.1 cu/ft was my guess on driver displacment per sub)
The drivers can also be mounted on the oppisite side to the port, depending on where you want the port firing.
The driver holes are 11" inch in diameter to show an example.
//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
angrytrucker78
angrytrucker78
St Louis, MO
angrytrucker78
