Some wiring questions
POWER WIRE:
What crimps are everyone using? What tool can I buy to crimp the terminals? I'm not good with soldering and have never used anything but screw on 1/0 terminals. Also, what terminals will fit the 1/0 KnuKoncepts wire?
SUB to factory head unit:
How do I do this in my '06 Charger, high/low converter?
Is there any way to lower the bass from the stock head unit's equalizer?
Thanks!
i whent to a local electrical store and got some 2/0 terminals. then iused the back side of my bolt cutters to crimp them. have been holding for over a year now no problem. i also used my bench vice to crimp them some more
I put my 0 gauge wire in, put it on the cement ground. Take some hard swings at the end of it with a hammer. Just make sure your wearing a glove to lessen the vibrations if you accidently hit the cement.
Mines been holding for.... 5 months with no problems. I did this KNU Flex 0.
Then put on something to cover it if you want like electrical tape or w.e
As for terminals, I just went to a local parts store and got some of the ?brass? ?aluminum? ?copper? ones that run for 2 bucks a pop under discount - welding stuff.
They can hold more than ~300A.
These are the best to crimp 1/0 IMO...
And cheap...
https://weldingsupply.securesites.com/cgi-bin/einstein.pl?Next::1:UNDEF:OR:terms::pA
Halfway down the page...
nG
Another possibility is what I do. I have a small butane torch. I heat and fill the connector 1/2 way with solder. I then insert the bared copper end into the connector and keep the torch on it for about 30 seconds. I've never had one fail.
Kenny Pollock
drag it!
Kenny Pollock
Hollywood, Florida Low: Yes
SethPhillips
