Need help wiring 4 2ohm subs to 1 ohm
xsupermario
My friend has 2 seperate boxes with 2 2ohm subs each. He was wondering how to get it to 1 ohm. He is using a 1600watt Hifonics class D amp to power it
He tried wiring it like this
But after hooking everything up it does not sound like its getting the power it needs to.
So my question is is that 1ohm or no?
and if it's not, if we were to run a wire from each negative and positive terminal to the other and then just go from one terminal to the amp would that be 1ohm?
Your diagram appears to be wired correctly for 1 ohm.
What's the model of that Hifonics?
Also, what kind of boxes? Sealed or ported and what is the cu ft? Box designs/size make a huge difference in 'loudness'
You should determine the cuft of one sealed section for a sub and let us know the sub model. We can then help determine if it's the right size.
Were the boxes custom built for these subs or prefab bought?
xsupermario
xsupermario
chicago, il
xsupermario
