Some wiring help, por favor
  • 2
I would recommend getting a wiring kit for a 500w amp or bigger.
Just keep in mind when you buy the kit, is this all you need or will you expand later. If you plan o expanding your system (more powerful amps, more speakers, etc.) get a bigger kit. if you want to buy everything separate here is a list of what you need for this setup, go with bigger power and ground wires, if you pla on adding more to the system.
power wire - about 20' of 8AWG wire
Ground - about 12" of 8AWG wire
Remote - about 15' of 16-20 AWG wire
speakers - I would buy a roll of 30' 14AWG wire
RCA's - 15' dual rca's (two male connectors at each end)
Fuse holder - 8AWG min, make sure to install this right off the battery, no more than 12" away. This should be the first device that the power hits.
Thanks for the input. Much appreciated. The dsp is an afterthought. I haven't installed anything yet but I put a budget system together. I already...
449
In a case like In a case like yours I would rather recommend tactile transducers. They are like woofers without the cone section that are...
7
849
Your image doesn't really show anything. That could be 3 different head units for all we know, but I think it's 2 different add-ons. It sounds...
934
Try again on the attachments/pictures. They didn't load. Not exactly sure on the wiring, but you can buy an adapter harness that goes from your...
LUNATIC HIGH
LUNATIC HIGH
Lake Forest, Ca
Steven
GoldCountryCA
    May 5, 2024
GoldCountryCA
    May 5, 2024
Latest topics
