How do I wire my sub????
IILAOPRINCEII
Hello Everybody!!
Can anyone help me, I have a Punch 800a2 and would like to know how I would wire a JL Audio w7 sub and get the most from the amp???
Thanx!!
I think that its only has a single voice coil and the indepenance is 3 omhs. Is there any other sub that would be better than the w7??
Thanx again!!
well if you have them id run the RF at 3ohms bridged. I know it doesent recomend it, but I used to run 2 500a2's at 2ohms all day, for 2 years. They were awesome amps I miss them. It can be done Id just suggest 4 gauge power& ground for the amp. You will probably get a million people that will tell you not to do this. But it does work
Would something like this work? https://www.crutchfield.com/p_204BTA1010/Bazooka-BTA10100.html
13
4K
the AVIC was a tad more complicated to wire not to mention stuffing it in a smallish stereo hole. thanks for advice.
8
377
Drill a hole and use the proper protective split loom and hole grommets to keep the outer speaker jacket from knicks and cuts, give just enough...
8
813
IILAOPRINCEII
IILAOPRINCEII
Windsor, ON
blackgeltabs
DEW123
    May 7, 2024
DEW123
    May 7, 2024
Latest topics
