some advice please
  • 2
Bridging would be the best option as bass is primarily mono in most applications. (some exceptions) This way- both subs will be similar in response and also produce a little better output.
Make sure your amp is able to handle the final impedence of the subs while it is bridged first though.
Take it easy,
-zane
Originally posted by slick rick i think my amp is 250@ 4 ohms, so if i get 2 8 ohm subs, and bridge the amp, that shu;d be good rite?
Yup!//content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
What model of MTX amp? If Memory serves- most MTX amps can take 2 ohms mono without much trouble- which in that case, you could use 2 4 ohm subs and then bridge the amp.
hows that?
-take it easy,
-zane
sounds good, its an mtx thunder 102, so if i can, it wuld be better 2 get 2 4 ohm subs, and bridge the amp rite?
on a side note.. it seems all the kicker comps ive seen r 'free air' models, will that effect how they sound in my sealed box
500
It also lowers the amps efficiency and raises the current draw.
634
788
I always leave approx 6" or so for that very reason, in case I decide to swapp an amp if needed,or wanting too.RCAs ect. I deff do the extra 6-8"...
889
Honestly, beyond what you need. It will do the trick for sure, but it is excessive. Not a bad thing, just more than you will ever need. No need...
slick rick
OG
slick rick
Violates Miranda
slick rick
maylar
    Jun 2, 2024
    Jun 1, 2024
