lol, it's kinda hard to just look at some guts and really say what makes it up. first thing, is you have to know what is what..... all those things clamped to the heatsink are transistors, and most of the time, a pair, or more(larger amps) of diodes, but i have also seen them mounted right to the board..... ok, here is a quick rundown- the ampo starts with the power supply. you will see these transistors, or "fets" as most you will ever see are mosfet. they can pretty much be identified by them being connected basically direct to the 12v inputs, usually right to ground. in this section, they switch the power(controlled by that cluster of smaller components nearby on the board, and sometimes their own little board, or "card" you will see them in mostly the smaller to-220 case, and can usually handle a typical 100-150, and even sometimes as high as 175watts as rule of thumb (this is not really set, just quick, and the newer, generally carry more load) sometimes you will see them in a larger to-227 case, which is typically doubble power handling, though you probably will only see it on old stuff, so i would place them in the 150-250 range(again, just quick glance rule of thumb) now, they alternate the 12v through the transformer "torroid" (round thing with wires wrapped around it) now, this, is more looking at the physical size. take for instance, the usamps old school ones barely had any wire on them, but still ran more current than some of the new balls of wire. there, it will hit the diodes, which could be little black cylinders with a silver end, or the to-220/227 cases. there, it is back to dc power. again, there is control circuits similar to the power supply circuit. and, you will see the output section of transistors. again, same thing applies as the power supply fets. difference being, is that the power handling is generally half what the power supply fets run. now, this, again, the newer, generally the more power each transistor can handle, and new designs are moving more to fets, verry similar to power supply fets, and the power jumps exponentially. for instance, i just repaired a soundstream rub1.1600d.... well, @1600watts, it only housed 8 outputs, but pretty much does rated..... the outputs are easily identified by the large resistors going to each one(either little roundish things with colors, or bigger white ceramic boxes.) i generally like to look at the ratio. 2 outputs per power supply fet is usually a good sign, and i count 1to-227 as 2 to-220's.... now, all of this, is just skimming the guts for about 2-3 seconds, and there is a tonne more things you need to know or look at/look-up/test to actually know, or get in a good ball-park. as to the regaurds of modifying an amp for lower impeedance, well, the outputs can only handle soo much current, and so much wattage. i have not done, or had the mod done, nor really have interest in it, but here is how i see it- ideally, if it is 4ohms, then you stand a chance there is some current to be squeezed, however, the wattage is probably already no more than you really want, probably a tad under stable limits. so, as long as the control circuits can accept it, and all the other variables, then the rail voltage will need to be dropped by re-wrapping the torroid or other power supply reconfiguring, and some other stability changes, including cooling, because lower voltage, higher current is usually higher heat, and likely less efficiency. if you want lower impeedance, use a more high current oriented amp. as for "made in usa, or assembled in usa, well, it's still usa that is building it, and i want my components to come from a place that can build it better, which is not america. i don't buy american fets, american caps, and don't plan on it for a while, but a good 'ole american heat sink, board, fateners, wire, quality control, etc.... well, that is a nice combination.... oh, and that treadmill would probably be built with american steel and rubber.... have you ever seen what it would cost to ship? not quite cost effective, atr least not if i was building one..... but, hell yah, i would buy the controller form asia, and motor from somewhere like mexico, or possibly even look for something us, or wherever.... besides, the us sticker gives any product a +1 in my book
