im sorry I worded that bad. I meant they would not stay on the amp, I could easily slide them off. Could be an eD problem though.Krystal are not a coaxial geometry cable. The Klarity, Karma and eKs all are and the ground is the shield on those with the eKs using a directional ground drain. The Krystal use a different design to be different from the others and they have worked well. The next redesign of that model is not to be released till 2009. The Klarity will get new look then a new Krstal line will be released
You mention the connectors came off, the ends are crimped onto the legs. The only way they come off is if you are not pulling them off by holding the barrel connector and breaking that crimps bond
I really doubt that. With the amount of voltage running through and little to no current going through, I really dont see an issue will occur. heck i even ran video through the same gauge cable before, I didnt see any video compromised resulting from this cable or that cable.I forgot to mention the internal conductors are 21.5 gauge on the Krystal RCA. If you are using 24 gauge, that would have a higher resistance then our cable, there by altering the path of least resistance by changing the cables, thus shifting the noise level but in turn could be hurting frequency response with a higher resistance.
Most mono amps still take a 2 channel input so any 2 channel RCA would be good for the application. Make sure you do get the right length:hey knuconceptz im a noobso i was gonna buy some rcas off your site
which one would i pick for a mono amp?
Klarity Kable Y adapter 1F2M RCA Kable
Klarity 2 Channel RCA Kable 1M
its all confusing to me
so you do not think 24 gauge has a higher resistance then 21.5 gauge? We'll have to agree to disagree on that one //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifI really doubt that. With the amount of voltage running through and little to no current going through, I really dont see an issue will occur. heck i even ran video through the same gauge cable before, I didnt see any video compromised resulting from this cable or that cable.
I dont claim to have golden ears or eyes for that matterlol but I would really like to see your shields grounded in your next line up even if I have to wait until 2009
