jeepintn
- Thread Starter
- #61
This is just a bad situation anyway you look at it because I and anyone else that reads this thread is going to tell you that Team Maxxsonics Db Drag guys are going to abuse the amps. Pretty plain and simple. I'm sure Big Oso and any other Team Maxxsonics guys are absolutely upstanding, but when it comes to Db Drag competitors, they seek to get the most that they can out of an amp. Also, Mike Stiers (Maxxsonics employee) told me flat out that the Goliath does not like anything over 5 volts through the RCA's. Bamaboy's situation is unique in that as soon as the amp saw power it blew, yet again another example of a previous user that probably abused the amp before Bamaboy. By no means am I an expert on this situation, but when I received my replacement amp from Maxxsonics and hooked it up @ 1 ohm with the same external crossover settings I used on my first Goliath, the amplifier got extremely hot so before anything bad happened I called Maxxsonics and talked to Mike Stiers and that is when I learned about the RCA voltage. I turned off all signal boosting on my crossover and wa-la the amp could suddenly run @ 1 - .5 ohm without getting even lukewarm.
I really hate that you are going through this. Good luck, I hope everything works out.
****, and my eclipse has 8v preouts :-\
