SMD VM1 install to Amp?
White goes to the remote wire. Also L.e.d. volt meters tend to be really bright at night. Id run a switch between the positive so you can turn it on and off. If it doesnt already have an on/off function.
Ok my thinking on the ground to the amp was because my amp ground wire runs under my truck and grounded to my frame.
that sounds like a long ground. with something so small i guess a self tapping screw will be fine. you can use the amp as a ground but its not right. i had my volt meter like that for a while
speedyjuarez
Premium Member
Premium Member
speedyjuarez
Live in Hobbs, NM. From Ft Worth, TX
speedyjuarez
