SMD DD1 or OSCOPE?
The DD-1 can detect all kinds of distortion, not just clipping. An o-scope (at least the cheap ones like the DSO nano which is $80 iirc) will only let you see clipping, but at the same time you can also do a lot more with it since it's more than just a box with a couple lights on it. You can't really go wrong with both though personally I would want to have the o-scope since it has a bit more capability, especially if you want to use it for outside of car audio
I have a dd1 and its kinda for spl purposes, or like a peace of mind instrument. With the dd1 you can check all your equipment and see if anything is distorting. For me nothing was. And then you can set your amp to the max output without distortion.
If you have a amp thats got more power than you need, for your your subs or mids. Then the dd1 is kinda useless, because if your gain is set low, then chances are you are not getting any distortion at all. Unless its a horrible amp.
I see, but then if the amp is more poweful, can you just set the level of the amp with a dmm my calculating the ac volts?
Yeah in that case I would just use a dmm. If you have a powerful amp, that puts out a lot more power than you need, chances are your gain is not turned up very much. And if your gain is not turned up very much, the chances that you have any distortion are slim to none.
But if you want to get the most out of your amp (distortion free) then dd1 is nice to have.
Ok kinda off my topic a bit here, bit I thought setting any amp with a DMM and no load on the amp (ie. only the dmm connected to the amp's output), would give a false AC voltage reading? So does that mean, that I need to have to sub connected to the amp with the dmm as well and set the gain that way?
I have an SMD DD1 and it's a waste of money. Best thing is using it for finding out the peak volume of your headunit, but even with those it'll only work with certain headunits, like higher voltage pre-out decks. For a daily driver maybe it's ok, if you ever plan to use your system for bass comps then forget it. A DMM will do everything this unit does, and a good O-Scope would work great too.
Hey has anyone tried that o-scope idea that uses the mic input of your laptop with some resistors and some recording software? Seems like everyone who tried it on the youtube video says it works well and is flexible cos you can change the input resistors to suit your power output... I might try this...
Using a DMM alone can be deceiving. You make the assumption that your amps make rated power and your HU is clean at whatever volume level you pick. A scope showed me that my amp puts out only half rated at 12V and my HU clips at 65%.
I've never used a DD1 so I can't comment on that. I wonder if it'd blink at you if your preout signal looked like this:
You are right, after spending many days I have discovered that nothing can really come close to a scope - I just invested in one infact //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif Awaitings its arrival!
No, it wouldn't show distortion with that waveform because that waveform is not clipped. Distortion happens when the peaks of the waveform are flattened out. That waveform isn't flattened and thus, isn't distorted.
I will as soon as I figure out how to private message someone.
Rentals wouldn't be bad you might even get a hit on DIYMA as well now and then.
  • Locked
COMPLETED SMD DD1
Money sent @DFS722
There are all kinds of Ideas out there by a search on the internet these days. Find the one that works for your situation and budget and...
  • Locked
COMPLETED Smd vm-1
Looking to buy a smd vm-1
momofx
momofx
IL, USA
maylar
    Jun 3, 2024
