Small ID build today
but on a positive note i have better pics of my amps and second max //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
ok i will explain because i too drive a gm and this exact thing happend to me, in the second and third picture those little hoses are drains for the sunroof, in each corner of the sunroof is a drain front 2 are located behind the front wheels area rears are located in the trunk. The rear drivers side looks fine but the passanger side looks like it was cut and never put back on the nozzle that leads to the outside of the car.
oh wow. you are officially my hero //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif that is the first thing im going to check in the morning. you just saved me a lot of troubleshooting. i looked around for an hour ish tonight and could not find anything.
dude check by the sun visors inside the car if your headliners ever wet and get some compressed air and shoot it down the hoses to clean them out, its funny because i literally just got done fixing the leaks and stuff in my trunk/headliner
ditch that tweet location. go with kicks if you can and you can just mount the set coax style.
hopefully by the end of the summer i can do that. i would like to have the tweeter in the a pillar possibly though with an off axis response, not sure if that would help raise soundstage or just make the tweeter too bright. however horns might be in the mix later on though //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
thanks for the advice. where exactly does the hose begin? do i need to pull headliner out?
Brian_smith06
I got a pan, I got a plan
Brian_smith06
Overland Park, KS
Brian_smith06
BP1Fanatic
BP1Fanatic
