Slap/tap sound from sub
JasonK94Z
Whenever my subs cone has alot of excursion, I'm getting a slap or a tapping sound from the cone. It is a Powerbass L-104D in a sealed enclosure with an Alpine MRX-M50 amp running it. Also using a AudioControl LC2i LOC. Gain is half way up (nom), LP is set a hair below 80 Hz, subsonic at 25 Hz. Sometimes I find myself wanting more, so I try to turn the sub up more using the remote gain control knob. Anytime there is a kick drum or something sharp like that, the cone taps. Annoying. Definitely happening during big excursions. May be time to try another sub in that box. Its a custom sealed fiberglass enclosure under the back seat in my dodge ram quad cab. Approx .70 cu ft.
I'm leaning towards no leaks. Lined the entire inside with automotive undercoating. Only leak spot could be around the woofer itself, but it has a good rubber gasket.
JasonK94Z
JasonK94Z
Olathe, KS
JasonK94Z
