Sky High 2/0 OFC
cas0586
WV
I purchased a couple feet of Sky High 2/0 OFC cable to use for my battery/chassis and engine/chassis grounds. I also bought 2/0 copper lugs and they certainly don't fit! I take it I need some 3/0 lugs for this 2/0 Sky High cable? Thanks!
SKy High 2/0 is near as big as 4/0 (actual 4/0). This is the problem with buying car audio wiring, there is no standard.... Welding cable has a set standard and they are all exactly the same. Not "this 1/0 is bigger" crap.. Just buy Sky High's 2/0 connectors or buy 4/0 welding cable connectors.
Thanks. Precisely what I did. Ordered a small run of 2/0 welding cable. My 1/0 run is welding cable anyways. Also I am not in the habit of trimming wire to fit a lug. Doesn;t make sense to me!
You are clipping at the HU, and as stated.. will eventually damage the HU if continued. sounds like you need a little more power as stated. A 2 ch...
300
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
906
Thanks a ton for your suggestion to my rather long query, I ll follow it and see how it works out. Thanks again
759
cas0586
cas0586
WV
negolien
