Skip01's: 2012 "End OF TIMES" rebuild
  • 6
That's always nice. I can have stuff delivered at my job as well considering we own it and since it's a lumber yard, it's "commercial". Cuts way down on cost.
Specs so far on subs:
3" coil 2.25" winding length
85mm xmax
Flat wound coil 18ga
2000wrms
10.25" spiders (12"-18")
8.25" spider (10")
True nomex material spaced on woofer for linearity of driver movement
But they are all custom built too customers needs, so things will change as needed
---------- Post added at 06:32 PM ---------- Previous post was at 06:32 PM ----------
Oh an this stuff came.....yessurrrrr:
Thanks for the link to this video, I've seen this one before but it's not for component speakers which is what I'm going to install and the part...
720
Try crutchfield.com and use the application that gives you replacement options for system components. I ripped out the entire system in my Mustang...
It is in eBay. It is a bit more complicated. You clip off the gray blocks on your radio's harness and splice in the new harness by color matching...
Nice, much better looking version Ford than its American counterpart. Go down to the local stereo shop and tell them you want to the work yourself...
Skip01
Diggy
Skip01
Marrero,LA
Skip01
SPLBassJunkie
    May 21, 2024
    May 20, 2024
