skar vvx10-v3 1.75@32hz
  • 7
pathfinderone
started experimenting with boxes, made a sealed enclosure for this woof at 1.25f^3 and it sounds pretty dang good. subs starting to break in now and really making a lot more noise! im digging it. first time experience with a real nice sub. I want to try making a ported box for it and then go from there depending on which one I like. ultimately I want to make a dual 10 box for two of these things. ive got it powered off a jbl 5501 amp and its doing pretty good. anyways pretty much looking for a second opinion on these box specs I have found to match the box specs on the enclosure specs on the website.
Vehicle : jeep cherokee
Location in the vehicle: trunk area
Space available (Length x Width x Height): lol a lot
Subwoofer make and model: skar audio vvx10v3
Subwoofer Size: 10"
Number of Subwoofers: 1 for now
Type of Port (Kerfed, Slot, Aero, etc.): slot for sure
What type of music do you like?: all of it... mainly metal and EDM..
Is your goal SPL or Everyday Music?: everyday music with some pants sh***ing loudness if necessary
Tuning Freq (Hz): 32hz
Volume : 1.75
Questions: question is this, here are my box specs ive came up with. do they match up and do you think I could improve them at all?
width: 23.5 height: 14 depth: 17
sub displacement .15, MDF width .75, hopefully port width of 1.5 and height of 12.5 with depth of 25
net volume 1.74
gross volume 2.47
tuning 31.9
port area 18.75
im making a slot port box and hopefully these dimensions are correct. can you guys see anything wrong? ive been researching as much as I can and I feel pretty confident about this.. and its as close to skars specs as possible. mainly trying to compare this sub with a sealed box vs a ported box and Id like the building experience. any advice? thanks guys!!
Thatd be cool, really in looking to understand everything a little more but i dont want to burn myself out researching and going crazy with everything. What did you have in mind?
---------- Post added at 07:30 PM ---------- Previous post was at 07:29 PM ----------
Oh dang! Well how far south are you? Maybe meetup and have a beers and bs about this?
Smokey Joint. I mean Point
Are you sure you need 1.75 NET for a 10?
I've got a 3" coil 10 in barely over a cube net with round ports. Tuning in the low 30's.
It slams.
I would think an xfl might like that much space, but vvx???? I'm not so sure.
thatd be a pretty quick trip down for sure.
so about the specs I posted, do they seem legit? id be looking at having to put a corner in the box for the port since its longer than the box is deep. would that be an issue? should I calculate everything differently based on that? anything I should be looking for?
---------- Post added at 07:40 PM ---------- Previous post was at 07:39 PM ----------
It slams.
not sure, thats why I posted here lol. the spec sheet for the sub enclosure recomends 1.75. id like to stay within specs but if theres something better I could do im all ears.
Be careful with Skar's recommended boxes if you got any REAL power... anybody remember the crud I went through with mine?.. I suggest you model them first to avoid compression, unless you like smelly coils... LOL!.. It may not apply to VVX series but better safe than sorry...
any suggestion on modeling programs?
If you give it a minute someone might help... I'm not going to step on it ...LOL!... I can model it ... but am only learning... so I'll leave THAT to the more experienced members... I'll only warn you to check the Skar specs and list your ACTUAL amp/load... not what the amp claims it'll put out!
get buck to help ya out
---------- Post added at 11:15 PM ---------- Previous post was at 11:15 PM ----------
right on, ill have to measure my actual output. the sub is wired to 2ohms with a final load of 3.5ohms at the leads going into the amp. ill try and get more info..
That's box rise for ya....quite a bit to.
I'll tell ya' that right off I see a potential problem... 18 in2 of port sounds low... as I stated... have patience...
The Sakr OFC wire is as good as any other for that price for sure, not talking about their amplifiers. If you have enough, dual 12 gauge runs are...
82
672
I had two Skar amps (4ch & a monoblock) go bad within a year. Post #2 is an excellent recommendation.
949
pathfinderone
pathfinderone
bellingham, WA
iLL Ridge
    May 18, 2024
    May 18, 2024
