Skar VVX V2 opinions?
Hey guys, couple questions about the skar vvx v2. I'm looking to do a build in my girlfriends truck and originally was going to go with 2 10's but I won't have the space for a proper enclosure. I've decided to go 1 12 with around 2-2.5 cubes net.
She listens to primarily hip hop and r&b so the tuning will probably be around 34-36 hz.
Just want to know if anyone has used the v2 yet and what are there opinions? Tried to look up some info on it but instead I just found lots of hate for the company owner haha.
I want to go the d2 model, wire down to .5 ohms. I'm guessing I'll see between. 1.25-1.5 ohms after rise into an elemental designs nine.1 so the sub will probably be seeing 1200 ish watts
Just realized I made an error. D2 wired to 1 ohm, not .5. Sorry about that. That will probably bring the rise to a little over 2 ohms I'm guessing? So more like 900-100 watts on the sub
D2 model can only wire to 1 ohm while will rise to right above 1 ohm.
You beat me to it! Haha thanks man.
I guess my main question is, will this sub be able to handle that much wattage daily? Say I am able to get 1200 into it, would that kill it quick?
If you keep the gains down. They are able to take 1k daily but 1200 might be a little much. Keep gains down for a bit. If that amp does 1200 at 1 ohm and 900 at 2 ohms, youll be fine. Still keep gain down a bit and smell for burnt coils.
Ok thanks for the input. I appreciate it. The elemental designs is rated at 12.8v instead of the typical 14.4 so their ratings of 900 @2ohm and 1200@1ohm are generally considered very underrated. For her electrical, I'll be staying with the stick battery up front and putting an old shuriken skbt55 I have laying around (still resting at 12.7) and big 3 upgrade but that's it so I imagine I'll be seeing some voltage drop.
Any recommendations as far as enclosures go? I'm not seeing much on what type of space they like to see
Are you building it or getting someone else to build it?
Badseed
Badseed
Erie Pa
Savackz
