Skar ev10 Power?
Hello,
I bought one of these several weeks ago.
It's rated at 400w/150w RMS.
It's hooked up to an old Legacy 300w peak. I can't find the RMS on that Legacy anywhere.
I'm pretty sure it was measured at 4 ohms per channel, and I have it running at 2 ohms per channel.
The EV 10 seems to be slightly underpowered. It has a tight suspension, a ton of excursion, and the amp will clip before the sub bottoms out.
Do you think that I should try a slightly more powerful amplifier?
Back when I was doing this before in the 90s, free air/infinite baffle subs had less excursion and suspension than this Skar does.
Whatcha think?
Regards,
Josh
it's only a 2" coil sub with 8mm xmax i would put more than 300rms to it with gain real low., only rated for 150w., the vd woulda been much better for cheap..
Hello,
I had to have a shallow sub. I'm thinking about getting another with higher power handling, but I need to reinforce the mounting first. RF has a decent one, it looks like.
Regards,
Josh
Hello,
Regards,
Josh
if u get more power and can't get sundown sd or can't fit a dayton, may as well save $ get the skar vd., know a guy had one for 3 yrs..
Wabatuckian
Indiana
BOOMINGRANDPA
