Skar Audio SK 85.4
  • 4
Schnitzel
Selling my used Skar audio 4 channel amp. Amp is in perfect working condition. Pulled it out of my last truck when I sold it.
Class AB Multichannel Amplifier
Compact & Versatile Design - Highly Efficient
RMS Power @ 2 Ohm : 125 Watts x 4 Channel (14.4v)
RMS Power @ 4 Ohms : 85 Watts x 4 Channel (14.4v)
RMS Power @ 4 Ohms Mono : 250 Watts x 2 Channel (14.4v)
Frequency Response : 20Hz~30,000Hz
Input Sensitivity : 6V~0.2V
Line Output : Yes
Low Pass Filter @ 12dB Slope : 50Hz~5kHz
High Pass Filter @ 12dB Slope : 50Hz~5kHz
Damping Factor : 300
Bass Boost @ 45Hz : 0~18dB
Signal to Noise Ratior : 105dB
Remote Gain Knob Included
Line Out RCA Connection
Mode Switch : Ch2/Ch4
Fuse Rate : 30 Amp x 2
4 Gauge Power & Ground Terminals
Dimensions : 350mm (Length) x 241mm (Width) x 64.5mm (Height)
Paid $300 for it new, asking $200 shipped.
I'm in Southern California. Local pickup works, and I'll knock some $ off since I won't have to ship it. Located in corona 92880
I had two Skar amps (4ch & a monoblock) go bad within a year. Post #2 is an excellent recommendation.
I usually build my own enclosures and didn't have the time to make another box, just happened to have the dual 12" box laying around. I see a 3.5...
Id keep with the warranty return. Id look at getting a different more reliable amp, and maybe Sale the Skar.. Thats me though. Seems like a PITA...
  • Locked
COMPLETED Skar Audio RP600.5
sorry been on bed rest due to back issues. Looking for max depth of 5.5” 2ohm load 350 watts 1ohm load 500 watts
Schnitzel
Schnitzel
Corona CA
rfluvinmf
    May 20, 2024
    May 20, 2024
