Jbl ms8
ace_800
Just pulled from my car last week. Will include everything as if bought new, headphones, CD, both hi input cables, remote. Only issues is that the cable was cut on accident, I did repair it and it works perfectly fine. Display still has plastic on it. Also, the rca input is a little loose. Again works perfectly fine, just don't use a very tight male RCA for plugging it in.
Type System Integration Digital Processor
Power Output 20W x 8 channels @ 4 ohms, 30W x 8 channels @ 2 ohms
Series MS Series
Audio Specifications
Number of Output Channels Up to 8
Maximum Input Voltage (Speaker-Level Input) 15V
DSP Time Correction Yes
Output Connections 8 x line-level; 8 x speaker-level
Signal-to-Noise Ratio (Line-in>Line-out) 90 (Line-in>Speaker-out) 85
Number of Input Channels Up to 8
Built-In Amplification Yes
Electronic Crossover Functions DSP, up to 8 outputs, 6dB/12dB/18dB/24dB/octave
Seating Position Optimization Driver, front passenger, front area, rear area
31-Band Graphic Equalizer Yes
Tone Controls Bass, Mid, Treble
DSP Equalization Yes
Maximum Output Voltage (Line Output) 2.8V
Frequency Response 20Hz–20kHz
Input Signal Conditioning Yes
Maximum Input Voltage (Line Input) 2.8V
Audio Connectivity
Input Connections 8 x line-level; 8 x speaker-level
Aux Input Yes
Other Features
Favorites Settings Up to 5
Remote Control
Remote Control RF
Surround Processing
Logic 7® Surround Processing Yes
Video Specifications
Display 128 x 64 pixel LCD
Dimensions
Display Depth (in) 2-7/16
Display Depth (mm) 62
Display Height (in) 3-1/8
Display Height (mm) 79
Display Width (in) 3-3/8
Display Width (mm) 86
Main Depth (in) 11-1/2
Main Depth (mm) 293
Main Height ( in) 2-1/8
Main Height (mm) 55
Main Width (mm) 187
Weight Display Unit (g) 80
Weight Display Unit (oz) 2.8
Weight Main Unit (kg) 2.9
Weight Main Unit (lb) 6.4
Weight Remote Control (g) 40
Weight Remote Control (oz) 1.4
250shipped
Included
ace_800
ace_800
Okinawa, Japan
dailyrider123
BP1Fanatic
BP1Fanatic
