Single Sundown Audio 10" Z Box
  • 7
Mike465
Ami Creations
2,858
Kennesaw, GA
Ok everyone this box was for a local customers single 10" Sundown Z.
Box is 1.68 cubic feet after displacement with 27 square inches of port tuned to 35Hz.
Great craftsmanship but I deff wouldn't have put the sub by the port opening like that.
Thanks. The driver is loaded a good distance away from the port.
What table saw do you use, I can never get the edges of my 45's to come out that smooth and sit so flush with the walls.
For the time being I use a Ridgid TS3650. I am going to be getting a new Delta cabinet saw at the first of the year.
+1 on a good solid table saw. Makes all the difference in flat accurate cuts and angles and edges. Mine's is crap.
Sounds like you need new coils. My Explorer with three 15's, appropriate birch box, fully sound-deadened interior, and a boat behind it does not...
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
378
637
Mike465
Ami Creations
Mike465
Kennesaw, GA
crucial24
slater
    May 2, 2024
slater
    May 2, 2024
