Single Sa8v2 enclosure help
Tat3rooski
So, I'm in the process of trying to build a tuned box for my sa8v2. I'm new to all this tuning stuff so, I'm not sure on all the specs. recommended volume is .6 to .75 and that is tuned to 35hz. I've been using the12volt.com calculator to give me port dimensions for a .671 cubic foot box I designed. The port is 1.5 inches wide and is 39.5 inches long (according to that calculator it's tuned to just under 35hz) After reading more about this sub, I saw that people were commenting that there should be around 20 sq inches of port area?? I've got way more than that. Anyone out there that has a spec box for an sa8v2? If not, I'll just need some more info from you experienced audio people! Thanks Oh, yeah, and I also emailed Ram designs with some questions. Are his designs any good?
I'm also in need of some help with a design for sa8v2. Can i get a box that's not going to take up too much grocery space in my family car's trunk?
My box is 27X10X10
Ther is a 1 1/4 spacer ring for the sub, the port is 8.5 inches tall and 1 1/4 wide. and i think it was 20 long. Play with those numbers and it will get you close and leave you plenty of room for groceries.
Mine really moves some air for a little 8" sub. It's not going to hit like a 12 or a 15 but it can still get low.
Tat3rooski
Tat3rooski
Wisconsin
™Caveman
