Single capable amp needed to push 2 12" bone crushers.
thats subs back port up. not the best loading position. Change it asap. Like we said subs facing up, port firing back.
I will turn the box after work.. It weighs over 50kg with the subs in it. ..moving it alone is a mission on its own but I can do it.
Sent from my MHA-L09 using Tapatalk
Yes those are my dimensions.. I'm beginning to get used to your imperial system. Even going as far as measuring using the imperial side of the measuring tape. Hatchback.
If you do rebuild this one will fit... remember subs up/port back... put the port on the left side as you face it in the car looking at it from the rear... assemble like the last pic in post #162 ...
That's good advice. Cheers mate.. I'm gona start on Saturday morning.. So I'll prob be in here chatting while I begin building it.. I Dnt have access to a 3d programme to model it.. The best I can do is 3D technical drawings. Do this tonight.
thats around how much one of my sub weighs alone. Imagine mounting 4 of them inverted and making sure the surrounds dont rub against the wood. All those people saying bicep curls are a useless exercise clearly never mounted heavy subs before, that helped a lot lmao.
Yeah... I have to call my 20 tear old son to handle my 30 lb subs... I couldn't even lift one of yours...
I mostly used type R subs. These are way heavier though... I'm not used to it.. It's more the size of the load than the weight cause I have to put the subs in the box an then load it in the car. I cnt mount them in the car. But with the sub up design I'll be able to easy.
---------- Post added at 09:16 PM ---------- Previous post was at 09:15 PM ----------
These weight Abt 20kg each. So 40 tats plus the box... I weight 65kg. In my own opinion I'd say I'm doing pretty well.
This is exactly the configuration in the Torres box I gave you... we've had some communication issues so I thought I should illustrate what it is that we are saying... LOL!
EXACTLY like this... OK?
[quote name='Boomin_tahoe']^^Is that your new burp box?
Btw Wellyboy, my subs alone weigh 50 pounds each.[/QUOTE]
Yep... just had junior over for some much needed assistance... baffle is only mocked up in pic... now done & ready to wire... not really a burp box either... tuned to 41 hz... it should sound OK... maybe a daily for awhile but should get pretty loud... took a month to model it up and decide on a final volume/tuning... we'll see... LOL!
Now ready for wiring/paint... etc...
This is how it should be configured... @Wellyboy
[quote name='shredder1']Yep... just had junior over for some much needed assistance... baffle is only mocked up in pic... now done & ready to wire... not really a burp box either... tuned to 41 hz... it should sound OK... maybe a daily for awhile but should get pretty loud... took a month to model it up and decide on a final volume/tuning... we'll see... LOL!
This is how it should be configured... @Wellyboy[/QUOTE]That's a huge box. Length wise it's too big... Height an depth look perfect. But I can make the required adjustments easy.
Wellyboy
Wellyboy
AU
Wellyboy
