Single Cab truck box help
Go with dual 10's, Mach 5 IXL's would be a good option since they love small boxes. If you can do the design part then you should be able to figure out the rest. I'd use dual 3" aeros, if you can fit them. Diycable.com has them on sale for cheap right now.
They're about $140 each, something like that. If you want to use the BL then just do sub forward and port to the side, assuming you have enough space for the port to fire into.
What sounds better, port firing to the passenger side, or drivers side? i can do either.
I think sub on the pass. side, port firing toward the driver's side sounds better... don't have the sub vibrating on your back, distracting IMO.
Not sure if a pair of 3" ports is enough, if you can swing a trio I'd do it.
I would add an ANL Fuse @the amplifier supply with its recommended 100 ANL fuse, and Keep the 120-150 @the Battery...
Hello, What amps should I use for this: 2xFocal Auditor Sub 12 Slim Focal Expert PS165v1 Can Focal FPX 5.1200 work or is too much?
Well the setup I mentioned cost around 1,000 USD in my country and an extra 500 USD for the DPS. HU? The car display? I plan to stay with original
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
666
bigbud747
bigbud747
Stillwater, OK
xShoWTeKx
