Single cab chevy
Nnbschevy
CarAudio.com Newbie
Ok so I have a 2013 single cab Silverado. I currently have a single sundown sa10 classic in a ported box behind the passenger seat to fit the sub I had to add a 3/4 msg spacer. I love the way it sounds but don’t like the fact that the seat has to be up quite a bit I was looking at getting rid of the whole setup and getting a new ported box built with 2-10s. Possibly going with 2 sundown sld or 2 sundown ev6. Any advice and what would sound better the sld or the ev6 and how it would compare to my sa10?
Depends on how big of a box you can get back there and be comfortable. If you couldn't fit the single 10" comfortably two is going to need double the box size. Go with 8s.
I think my main problem is the fact I had to add the spacer due to the sa10 having a bigger mounting depth. From the research I did I should be able to comfortably get about 2 cubic feet so I think 10s would work. I had looked at some 8s also but most of them are deep as well I’m thinking I need something with about a 5.5 mounting depth.
Console boxes work sweet in those trucks rear firing port and sub ...I have a late 2011 Silverado standard cab ...10s work best but a 12 should work due to width between seats ...
4 or possibly 6-6½'s. I know that 4 will fit for sure. What is your goal? If you want more, then, you will have to go shallow mount (JL13tw5's) or blow through from the bed.
How would 4-6.5” sounds compared to my sa10? Really I’m not looking for something huge to do a blow through. The sa10 sounds amazing but it’s just a little too deep. I figured if I ran 2 with a mounting depth of around 5” it could be louder. I’d have about 2cu ft or so
This went in a single cab Silverado, is powered by a sfb1500 and exceeded the customers expectations. The particular subs are "underpowered" Imo (Rds 6.5's) but are certainly exceeding the output of a single Sa-10.
26662
The center console needed shifted forward an inch on the seat frame but it was a snap, almost zero loss of leg room or recline either.
26663
The pic above was the test fit, once the console was shifted the thing fit like a glove and is begging for more power. It does well as is tho.
That’s a sweet setup, Is the center seat still able to go up and down? I’ll probably look into something like that with maybe 4-a a6.5” or maybe 2 or 3 e series 8s. I have 900 watts to feed them.
I would have to ask the customer or installer but I think I would have heard something if any function was lost. Shifting the console an inch gave nice clearance is all I heard.
I like the E series but I love these 6.5 that are available thru a local supplier. The brand is newish but solid imo. Overbuilt and underrated. I talk smack to him constantly about his 8's. 8" subs seem to find a way into underseat enclosures and these things can be a challenge to fit... lol
26665
The 6.5" subs are like 5.5" depth iirc and very beefy too.
Rds audio” Don’t dis the six” ? Those are some beefy 6.5”’s
What’s the price on those?
I wont quote pricing as I've seen him put em on sale for pretty cheap at times.
Those little (hehe) 6.5's are surprising, The output/extension you get out of an enclosure this size blows most folks away.
26666
I can't do quotes... sorry.
I just used to do designs.
These are also very good options for your truck. The mounting depths are perfect for your application. I would suggest four VFL- 6-½'s on a Sundown SFB2K. IIRC the mounting depth is 5".
Nnbschevy
CarAudio.com Newbie
Nnbschevy
Tulare
Bobbytwonames
