then it wouldnt be even sounding for both pass/driver. i kow my trucks.....just didnt go over this precise designMake the hole a little bigger on your first piece and use it as a flush mount. Cover your hole you have now with that flush mount piece, and put the sub away from the port mouth inside the box.
Which way? Also it could have gone a lot further to the driver side, but the seat belt was in the way.ahhhhh i should have went over a little bit more than i did....
Well he will be running quite a bit of power, if it doesn't work we can always build another box.you should be fine with that but it will unload pretty easily. that's the only issue with it. had i been thinking i would have had you do a zig zag port near the pas. side.
ill get on it for you after i do murderlaunche's box....Which way? Also it could have gone a lot further to the driver side, but the seat belt was in the way.
No it is firing into the port wall, or at least about 2/3rds of it. I think the entire motor was in front of the port wall, if that makes sense. I was more worried about the fact there is only about 3" of clearance btw the sub and the port wall. Maybe I need to take a pic from a better angle.Your sub is firing right into the port opening.
Well I didn't pay you to design me a box, you guys just helped me sort out a few things, all on me. I should have looked at it a little better myself. I didn't even think of it when I was marking where to put the sub.then it wouldn't be even sounding for both pass/driver. i know my trucks.....just didn't go over this precise design
could but it wouldnt load the port correctly and could throw off tuning. that box should be fine though.... or you coule flop it around and have sub/port on the driver if its that much concerning.
That's what thought.could but it wouldnt load the port correctly and could throw off tuning.
Not to concerned about it just thinking, inside the box I guess.that box should be fine though.... or you coule flop it around and have sub/port on the driver if its that much concerning.
