Hey guys.. I've basically figured out my semi-budget $900 build,.. and I'm running two 6.5" Mids and 3/4 component tweeters that run at 100rms.
I am running off a AVH-P4100DVD Head unit.
Will be running a Custom box to fit where the factory sub does (.66 Cubic Ft, sealed).
In this Custom Box, I will be running a JL Audio 10" W0 (maybe W1)
And the Amp is 4 Channel,.. Two channels run at 120Watts RMS a piece,.. and I will be bridging the last two channels for 400 Watts RMS (Stable at 4 OHM) for the Sub.
Simple setup, but effective.
The question is,... Is it safe and "ok",.. to run 120watts RMS to a 100watt RMS rated Front Stage Mid + Tweet speaker?
On the same token -- Depending on sub.. The rated RMS may be 350watts, or it may be 400watts (400 to 400 I know is fine). So technically the sub, if picked, could be obtaining 50 more watts RMS than it's rating.
I've heard a few things .. but the two black and whites here are:
1) No! That will ruin your speakers.. it's too much power, do NOT exceed the RMS spec.
2) Yes, it's fine. That gives the amp headroom , it doesn't have to work AS hard,.. and the speakers will be fine.
First, which is it? And no matter which line you take, do you mind briefly explaining why that is the case?
Appreciate your help!
