Shuriken SK-BT60 Battery
  • 5
dross93ranger
1. Product:
2. Specs:
SHURiKEN AGM Car Audio Power Cell
This SHURiKEN 12-Volt Car Audio Power Cell features a sealed absorbed glass mat (AGM) design and is perfect for 1400-watt car audio sound systems. The SK-BT60 can be used as a replacement for your vehicles standard battery or as an additional battery to provide the extra power needed for a high performance aftermarket system. It's unique spill free design allow this power cell to fit in most factory battery locations with no hazardous leaks.
SHURiKEN's SK-BT60 Power Cell puts out 1500 cranking amps with a 60 amp hour rating. This battery will resist extreme heat conditions and vibrations and is 100% sealed in a reinforced ABS plastic case. SHURiKEN has designed this power cell to be used with ring terminals or a buss bar. You will love the way SHURiKEN batteries get your system powered up and ready to go!
Battery Features
12V High Performance AGM Power Cell Battery
For use with audio systems up to 1400 watts
Engineered specifically to meet the needs of a high end audio system
Using AGM (Absorbed Glass Matt) technology allows the battery to be mounted in any position
Unique spill free design
Extreme heat resistance
Resistant to heavy vibrations
Super low ESR
Packed closely with pure lead plates
100% Sealed and maintenance free
Designed to be used with ring terminals or a buss bar
SAE Posts available: Shuriken SK-SAE35-100
Authorized Internet Dealer
1-year Manufacturer's warranty
Battery Specifications
Amp Hours: 60
Cranking Amps: 1500
Weight: 40 lbs.
Dimensions: 5-1/2"D x 9"W x 8"H
3. Description/Condition:
This battery is right at a year old, resting voltage 12.63
4. What you are looking for: :
Small mono amp, 8 or 10" subwoofer, with or without a box. I will also trade for a flip-out DVD headunit. Will consider other trades (amps, s10 parts, ranger parts) and cash offers.
5. Pictures of your item for trade:
any way u can charge it?
I actually just put it on the trickle charger a couple hours ago, I will update the resting voltage when it is done. I just interrupted the charge and let it sit for about a minute and it read 13.1v
Update: Voltage has been holding steady for 3 hours at 12.63, I believe that is the final resting voltage. I am open to cash offers as well as trades.
dross93ranger
dross93ranger
Maysville, KY
dross93ranger
    Jun 1, 2024
    May 31, 2024
