Showdown: RF vs Polk
which comps for my frontstage?
  • Total voters
    16
emilimo701
i know i'm being a b**ch but i can't make up my mind...
Rockford Fosgate Power T1652-S for $170
or
Polk Audio MM6501 for $200
In the mail, I have coming a pair of Rockford T-1652 coaxials for my rear stage, and a Hifonics ZXi150.4 amp with these specs:
150w x 4 @ 4Ω (.05% THD)
300w x 4 @ 2Ω
S/N 80dB
damping factor >180
If i dislike the sound of the rockford coaxials i get, i'll clearly go with the Polk. But i've seen pretty much only good reviews about both. The Polks supposedly handle 25 more watts and have 2.7 ohm impedance; so by my calculations they will receive 222 (right?) watts instead of 150, meaning i can lower the gain to achieve the same loudness relative to the rockfords. But the T1s will match my rears, and they look damm sexy (which is a plus, because they will be exposed in my temp setup, and maybe perm) and i'm also guessing they might be underrated.
Help? I'm assuming since they are fairly popular/common products, i might be able to find a few people who have heard both. I think Misfit is one of those people.
thanks for the suggestion!
power handling might be a little too low though? i forgot to mention that i plan on cranking the Zues. not turning the gain up to 100% (i want it to last lol) but i'm hoping to get at least 2/3 of its rated power out of it, or as loud as possible without risking the safety of the amp/speakers. Not only will i be listening to music in the car, but also for tailgating where i might turn it louder than usual. This is a kind of temporary setup, but it will be used for at least a few months, and might use whatever i end up getting for my new car when i get it
You set your gains according to what is feeding the amp. It is not a volume knob. I am sure there are plenty of write ups around here on the subject.
/facepalm
dude seriously. i pwnd u. if for still for some reason you think you can explain what you were trying to say then say it. dont try to cover up by doing a cute /facepalm thing!
//content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif
if you can successfully explain the magical difference between a gain & volume potentiometer (besides how some may integrated at different points on the circuit -- different means to same end) i will mail you a cookie. chocolate chip.
Polk over RF everyday for speakers
this.
Polk only makes/sells speakers, if they have any series of speaker that sucks the whole company will fail. if RF has a speaker that sux, ppl just use their amps/wire/signal processors/etc... Polk will not put out a bad set of speakers unless they have other types of products that can keep their business running.
emilimo701
emilimo701
Boston, MA
kevin lu
michigan born
    May 14, 2026
michigan born
    May 14, 2026
