False. The battery's - terminal is THE ground for the cars electrical system. It is the only actual ground in the car. Grounding to the chassis is the electrical equivalent to splicing into something else's ground
True, and in some cases perfectly fine.
FALSE
Ground loop is a common problem. if it wern't, there wouldn't be a sticky about it
Also, the current from EVERY CIRCUIT IN YOUR CAR runs through it. Thats why you don't get ground loops. A ground loop is a separate loop considered ground feeding into a true ground.... not a direct path of its own (I.E. directly to the battery.)
FALSE. There is almost 0 resistance in 4 or 8ga wire. Guaranty if you ground a multimeter somwhere in the back of your car, and go to the neagative post of your battery there will be much more resistance then if you measure even a 20ft (long for car audio) peice of 4 or 8ga ground cable.
nty
FALSE
Do you think that a 1/2" thick piece of copper has more potential to carry current then literally a ton of steel and/or other alloys.
The chassis is a noisy place, probably the worst in the car. I think the reason you see people with these massive systems running there own grounds with 0ga or better, is cause if your putting that much into your system you are well informed and trying to set yourself up for success from the start.
In short, the battery is usualy the best spot to ground, though the addition of a long strand of high gauge wire is expensive for the ground, which offten can be taken from the chassis with no ill affects and save money. Though if you take this route, at the very least perform the big 3 so that the wire comming off the battery and going to the chassis isnt the choke point in your system.
