Should I wire digital volt meter to battery or speaker terminals ?
mrpep
chicago
My digital volt meter came today and I originally bought it to watch the battery voltage but I do have a dial in my dash and I can see that I never dip under 14 volts. Since it seems so good I feel like using the volt meter on my speaker terminals so I can observe the voltage going to subs when bass hits hard. I'm thinking I can calculate tune voltage using a 60hz tone and then observe that I never go over. Is anyone doing anything like this ?
I don't think amplifier output voltage and vehicle power voltage would have much if any relationship at all. I do not know this as a fact but this is my hunch
you can not hook it to speaker output. 1- thats ac voltage 2- thats not where you read power for battery.
hook to the amps power input as thats generally where the lowest point will be under load
I don't see any point as music is so dynamic your readings would be jumping all over
There would only be a couple instances where you could use it and even then it's only voltage so it's not telling you the whole picture
Wire it to you + and neg on your amp terminals
You are probably dropping to mid 12v at your amp terminals
ok, so ac wont work , got it , now how about placing the volt meter on the battery under the hood? To minimize work and running all new wires? Isn't the battery the volts the same whether its up front under the hood or back going into amp ?
technically they're all in parallel, but that doesn't factor in resistance and drop due to the wire. so your voltage will read higher than it actually is
read this pep, i regularly refresh my knowledge with stuff like this: A.C.-D.C.
Charging System Basics
WIRE
Resistors
the last two are provided if you want to learn some new technical information, it's very related
If you want to skip out running 2 wires running to your amp to make sure it doesn't pop, then don't do car audio. 2 wires isn't anything compared to what some people run from their car front to back.
really? I'm completely clueless but thanks for filling me in....
Just do it right the first time, Just the red on the voltmeter to the poewr on your amp input and ground from black on voltmeter to ground, and can remote wire to the amp as well.
Just do it right the first time, Just the red on the voltmeter to the power on your amp input and ground from black on voltmeter to ground, and can remote wire to the amp as well.
oh ok, thanks .... so red is power and black is ground, got it ..
It’s nice having a test bench. That one is nice and clean! I don’t have pics of mine but mine is built all out of wood with carpet top and all...
16
The CT's are nice, That Sundown is a a frik'n beast!
971
2012 Nissan altima SR The trunk not ready to take back seats out I'm happy with the front and rear stage sub stage also I have a Sony DSX M80...
10
794
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
929
mrpep
mrpep
chicago
mrpep
