Should I use Re's ported box recommendations for a 15" Se ?
  • 2
bosco2023
Of course this sub has been around for years now and I have one of the older style se's. the recommend optimum ported @ 4 cubic net and 34hz. With all that said I am ready to build a round port enclosure that is 4 feet net plus .17 displacement for the sub. A round port tuned to 34 hz ( 6" inside diameter X 12.09" in length) which has an internal volume of .19 cuft. So gross volume is close to 4.36. Am I going in the right dimensions or should I shoot for 32hz with a port at 14.21". I have to play around with dimensions in my 97 Grand Prix trunk cause I want to fire up but don't know if I want to fire round port out of the side or they the ski hole behind the rear armrest. Also, I'm worried about port velocity with one 6" port. I like to use PVC and flare both ends. My alpine type r does awesome in a 2 foot net box tuned to 31 hz with a single 4" port at 13" long and port noise is negligible. The re will be run off of a hifonics amp at 2 ohm at about 1100 rms. this is a daily set up playing mostly rap, bass heavy songs and some rock.
I know I haven't provided dimensions, but I have to decide where my batteries and amp are going.
Thank you for the input.
Rich
The CT's are nice, That Sundown is a a frik'n beast!
667
2012 Nissan altima SR The trunk not ready to take back seats out I'm happy with the front and rear stage sub stage also I have a Sony DSX M80...
10
599
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
687
Do you know what the box/port tuning is? And what is the db/octave slop on the crossovers being used? Setting the amp crossovers as open as...
979
bosco2023
bosco2023
Hagerstown, Md
bosco2023
    May 12, 2024
Brendon Jenness
    May 11, 2024
