Should I get Dual Voice Coil?
  • Thread starter Unregistered
  • Start date
  • Replies 3
  • Views 464
  • 2
U
Unregistered
Guest
I'm thinking of getting twp 10" Infinity Perfects. Can the DVC model be hooked up as a standard sub and run at 2ohm? The price is the same for DVC or Standard, so what should I do?
Deffinatly the dvc so many more wiring options and flexibilitys and should cost the same plus i dont think they make a svc perfect.//content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
It depends on what amp you want to use. Do you already have your amp? What is it and will you want to add another sub later. for example if you wanted to get another sub later and you had dvc's you could only run either a 4 or 1 ohm load but if you had 2 single coils you could have a 2 ohm load. So it depends on your amp and if 1 will be enough for you.
sure the 10'' infinity perfects will work
just get the dual 2 ohm voice coil subs
and wire them in series/parallel for a
2 ohm load to your amp.
now a question for you.
is you amp 2 ohm stable when in
a bridge/mono load
No reason you can't get the sound you want with ported or passive radiator but if you have no ability to tune the mass of the passives you will...
The CT's are nice, That Sundown is a a frik'n beast!
772
2012 Nissan altima SR The trunk not ready to take back seats out I'm happy with the front and rear stage sub stage also I have a Sony DSX M80...
10
657
You can get close with tones, but music signal is all OVER the place in both frequencies and voltages. Like, if you listen to rap, the bass line...
763
Do you know what the box/port tuning is? And what is the db/octave slop on the crossovers being used? Setting the amp crossovers as open as...
Guest
SPLBassJunkie
    May 21, 2024
    May 20, 2024
