Shifting in "Auto" cars
miker
Wayzata, MN
So.. I have an old BMW w/ and automatic tran.. What I want to know is, why are the RPM's it shifts at variable??? Like sometimes I will get it up to 6k rpms, then it shifts down to about 4k, then it will shift down again at about 5k... But allot of the time it usually goes up to about 3.5k-4k... then shifts out of 1st....
Why would it be doing this?
Also the car "red-lines" at 6.5k-7.5k.. It's not "bad" for the car to get up into that range for a split second is it?
Just something to note.. It's not b/c the car is cold.. I'm talking about yimes when it is fully warmed up.
it's either your foot, or it's just an old pos
Well considering most of the "old pieces of ****" I have seen struggle to get to 80mph... I don't think thats it... lol... It is old, but it's no a POS.
trannys work off pressure...depending on the pressure thats building up, it will either shift early, or shift late. barley on the gas, means a light early shift. WOT, means a hard later shift. and everything in between.
now im going to assume the OP already knew this, and is wondering why it shifts at 3k and then a 5k even though you keep the throttle in the same position? im pretty sure the OP is a little brighter than assuming it will shift at the same rpm regardless of throttle guys...
Thank you:)
Yes. I am wondering why it shifts at different RPMs w/ the same amount of pressure (roughly)
Thank you:)
how old of a car are we talking about? is it possible the tranny is electronically controlled? maybe the sensor is giving bad pressure values which is causing unstable shifting.
not to familiar with bmw's at all really though.
I suspect it's an ignition problem rather than a transmission problem. Start with the basics: plugs, wires, coils, check engine codes. Does the...
841
you did. https://www.caraudio.com/threads/double-din-cd-player-with-screen-mirroring-a-link-android-auto-budget.614240/#post-8864499 OP:
AGAIN sonic does the same install stuff for free as well! Get a head unit with 4v preouts and 6 rca preouts as well they will be setup as front...
19
miker
miker
Wayzata, MN
JLJunkieMX107
    May 24, 2024
    May 23, 2024
