Shammy's Sonata Trunk Build
So your saying you can tell how much life an amp has left looking at it??
I can tell how much life an amp has in it if i was the previous owner.. Now this guy is telling something that isn't truthful about the mechanicals about the amp. There've been little lies throughout the sale i'm catching onto
Also there are blemishes on the amp that look like something thermally failed in his car that's besides the point though
friend, you don't even knew what a clipped hu signal will do. you certainly can't tell when an amps dying. you received a working amp, ran it on woefully inadequate electrical, with no idea how to properly set anything on your setup (as advertised by your posts in this thread), blew it due to use error, and are now trying to screw the seller because you fucked up. you're su scum, just as bad as any scammer.
I goy in a hurry once and hooked up an RF Power 2000.1 with a run of 4 ga. plenty of voltage but I knew not enough current. Well did some drinking and started pounding it then it popped. I knew it was my fault for not feeding it enough current so it was what it was, my fault. Your situation may be different, but sounds similar to me.
It may sounds similar but my electrical is solid enough for the 3000 rms i assume i was seeing.
Idk how the hell you popped a 2500 when i've seen T3000 on 4 gauge slamming all day
Because the 4ga couldn't provide the current required. Voltage and amperage are not the same. I'm glad you've seen people not blow up amps with less than ideal electrical support, but it happened to me and I knew why and took responsibility for it is all. hope it works out for everyone.
I'd take responsibility if the amp was hot as **** and able to fry an egg on it. Or if it blew the first day my sorry *** started playing it. But no it blew in on one of the easiest times i was going on that amp. That's enough for my to believe the amp took a ****
shammyhavik
shammyhavik
cali
adulbrich
