shallow box thinking sundown
jeffers
hey i have a little del sol im trying to add a little something in. i have 2 truck boxes mounting depth around 5.25" .71 cubic feet of space. i have done a little research and am leaning towards sundown sd's 10". i have a kenwood amp 2 channel that runs 100 watt rms. will upgrade the amp later but would like to get started with the subs.
so should i get the sd d2 or d4 and would this sound good or not. looking for opinions or better idea's let me know what you think.
thanks,
also have a friend that has a class d mono something around 750x1 2ohm and also has a 2 channel pussing 300x2 at 4 ohm that i might buy. what ones would you suggest? i just dont want to mess it all up when i could have done something better and this is all happening spur of the moment type deal.
well fellers thanks for the help i guess im going to go with a hifonics glx1400.1 and 2 sd-10 d2 as there is no reason to run them on 1ohm. 2 ohms will max them out on the rms and will be less stressful on them i believe. going to purchase all tomorrow. unless i can hear some valid reasons not to and do it a different way. these are going inside the cab of a del sol so should be plenty loud. currently have 2 alpine e's on 100rms each from a very old install but when i put them in the sol cause i was tired of hearing nothing good so i used what i had. the small enclosure made them sound horrible and after 2 days this is why im in such a hurry to upgrade. went from going to do a install that should only cost about $100 for the boxes so made it sound reasonable with the gf. to new boxes, subs, and amp..... shhh. hope this does the trick. please feel free to share.
thanks,
jeffers
jeffers
indiana
jeffers
