Shallow 13" Sub in Box Precision Power
trumpet
Barry Schanz
Atrend modified slim sealed box
Condition: 9/10, Used
Acoustic engineers want 3 things out of a woofer: high SPL, low frequency response, and small air requirements. No woofer can be optimized for all 3, so some sacrifices always have to be be made if a woofer has a very specific design goal...
Many vehicles do not have tons of airspace available for a big, bulky enclosure. Some vehicles, like some crew-cab trucks have no space for a subwoofer. Until now... Phantom-13 is the shallowest woofer on the market! Coming in at a mere 2" of depth, they will fit comfortably behind rear crew-cab truck seats, under many front seats, or even in a friggin' door with some custom fabrication! While other "shallow mount" subwoofers are available, they typically require traditional airspace. Phantom-13 is 13.25" in diameter and boasts a huge 5" coil with inverted motor. Not only does it play well in ½ cubic foot (typical for most 8"-10" woofers), but it reproduces more lower frequency response than most 12" woofers with much larger enclosures.
Our engineers were willing to sacrifice a couple of dB of efficiency to bring you a truly phenomenal, application specific subwoofer. No more whining about not having a subwoofer available that will fit in virtually any vehicle!
RMS Power (watts) 200
Efficiency (1w/1m dB) 80.82dB
Voice Coil Configuration 5.00" SVC 4Ω
Mounting Depth 2.00"
Optimum Sealed ft3 0.75
Optimum Ported ft3 N/A
Proprietary Cast Aluminum Frame
Inverted Motor Assembly
PP Coated Pressed Paper Cone
Polyurethane Surround
2" Mounting Depth !!!
5" Aluminum Former Voice Coil
Requires only .75 ft Box!
Semi-Circular Frame Venting
12ga Direct Connect Wire Terminals
Polyurethane Mounting Gasket
24" x 15" x 6" from the back of the enclosure to the front of the sub, additional clearance required in front of the sub
very nice sounding low power sub setup that takes very little space
$125
$15 shipping to the lower 48 states
trumpet
Barry Schanz
trumpet
St Cloud, MN
MAkahveli
